Imports data from NPAC files into LSMS databases. This command performs all parameter checking, and validates or creates the NPAC directory if required.
import
The user must be defined as a member of the primary group lsms.
Provided the import command is prefaced by the $LSMS_DIR environment variable, it can be performed from any directory location.
LRN.<create>.<start>.<end> NPANXX.<create>.<start>.<end> NPANXXX.<create>.<start>.<end> SPID.<create> <npanxx>-<npanxx>.<create>.<start>.<end> <npanxxx>-<npanxxx>.<create>.<start>.<end>Where:
<create> is the file creation timestamp: <DD-MM-YYYYhhmmss>
<start> is the start of the time-range: <DD-MM-YYYYhhmmss>
<end> is the end of the time-range: <DD-MM-YYYYhhmmss>
<start> is 00-00-0000000000 and <end> is 99-99-9999999999
Example 1:
<npanxx>-<npanxx>.<create>.<start>.<end>:
303123-303125.02-11-1998133022.12-10-1998080000.13-10-1998133022
Example 2:
LRN.<create>.<start>.<end> [Active (not time-range) file]:
LRN.02-10-2001102201.00-00-0000000000.99-99-9999999999
NPAC FTP directory: /var/TKLC/lsms/free/data/npacftp/Midwest
The following NPAC download file(s) are available for import:
LRN.11-07-2001145342 NPANXX.11-07-2001145342
NPANXXX.11-07-2001145342 SPID.11-07-2001145342
000000-999999.11-07-2001145342 0000000-9999999.11-07-2001145342
Import LRN.11-07-2001145342 (Yes/No/All/Quit)?all
The following NPAC download files have been chosen to be imported:
SPID.11-07-2001145342 NPANXXX.11-07-2001145342
NPANXX.11-07-2001145342 LRN.11-07-2001145342
Do you want to continue (Yes/No)?yes
Beginning Delete Process for SPID.11-07-2001145342
Delete Process Completed for SPID.11-07-2001145342
Beginning Download Process for SPID.11-07-2001145342
1000 ServiceProvNetwork instance updates in MidwestDB
2000 ServiceProvNetwork instance updates in MidwestDB
2351 ServiceProvNetwork instance updates in MidwestDB
Import completed successfully.
Download Process Completed for SPID.11-07-2001145342
Beginning Delete Process for NPANXXX.11-07-2001145342
Delete Process Completed for NPANXXX.11-07-2001145342
Beginning Download Process for NPANXXX.11-07-2001145342
1000 ServiceProvNPA_NXX_X instance updates in MidwestDB
2000 ServiceProvNPA_NXX_X instance updates in MidwestDB
3000 ServiceProvNPA_NXX_X instance updates in MidwestDB
4000 ServiceProvNPA_NXX_X instance updates in MidwestDB
30000 ServiceProvNPA_NXX_X instance updates in MidwestDB
30860 ServiceProvNPA_NXX_X instance updates in MidwestDB
Download Process Completed for NPANXXX.11-07-2001145342
Beginning Delete Process for NPANXX.11-07-2001145342
Delete Process Completed for NPANXX.11-07-2001145342
Beginning Download Process for NPANXX.11-07-2001145342
90 ServiceProvNPA_NXX instance updates in MidwestDB
1090 ServiceProvNPA_NXX instance updates in MidwestDB
Download Process Completed for NPANXX.11-07-2001145342
Beginning Delete Process for LRN.11-07-2001145342
Delete Process Completed for LRN.11-07-2001145342
Beginning Download Process for LRN.11-07-2001145342
1000 ServiceProvLRN instance updates in MidwestDB
2000 ServiceProvLRN instance updates in MidwestDB
3000 ServiceProvLRN instance updates in MidwestDB
4000 ServiceProvLRN instance updates in MidwestDB
4700 ServiceProvLRN instance updates in MidwestDB
5700 ServiceProvLRN instance updates in MidwestDB
Download Process Completed for LRN.11-07-2001145342
Beginning Delete Process for 000000-999999.11-07-2001145342
All Subscription Version instances deleted from Midwest
Delete Process Completed for 000000-999999.11-07-2001145342
Beginning Download Process for 000000-999999.11-07-2001145342
1000 SubscriptionVersion instance updates in MidwestDB
2000 SubscriptionVersion instance updates in MidwestDB
3000 SubscriptionVersion instance updates in MidwestDB
4000 SubscriptionVersion instance updates in MidwestDB
4500 SubscriptionVersion instance updates in MidwestDB
Download Process Completed for 000000-999999.11-07-2001145342
Beginning Delete Process for 0000000-9999999.11-07-2001145342
Delete Process Completed for 0000000-9999999.11-07-2001145342
Beginning Download Process for 0000000-9999999.11-07-2001145342
1000 NumberPoolBlock instance updates in MidwestDB
2000 NumberPoolBlock instance updates in MidwestDB
Download Process Completed for 0000000-9999999.11-07-2001145342
Script completed.
Table A-11 shows the files for the import command.
| Filename |
Type |
Location |
| <filename> |
Download file |
/var/TKLC/lsms/free/data/npacftp/<region> |
| <filename>_FAILED |
Error file, created if errors occur during import. If the -c option was not specified, the file will contain at most one entry. |
| <filename>-<spid> |
Response file |
| Exit Code |
Message |
Cause |
Suggested Recovery |
| 7 |
Delete utility failed |
Contact the My Oracle Support (MOS). |
| 8 |
DNLD utility failed |
| 99 |
Insufficient arguments Usage: import <region> [<filename>...] where <region> is the name of the NPAC region database: Canada, Midwest, MidAtlantic, Northeast, Southeast, Southwest, Western, WestCoast <filename> name of the NPAC download file: SPID .dd-mm-yyyyhhmmss LRN .dd-mm-yyyyhhmmss NPANXX .dd-mm-yyyyhhmmss npanxx-npanxx.dd-mm-yyyyhhmmss |
Invalid number of parameters supplied |
Try the command again with correct syntax. |
| 1 |
Invalid NPAC Region. Usage: import <region> [<filename>...] where <region> is the name of the NPAC region: database: Canada, Midwest, MidAtlantic, Northeast, Southeast, Southwest, Western, WestCoast <filename> name of the NPAC download file: SPID.dd-mm-yyyyhhmmss LRN.dd-mm-yyyyhhmmss NPANXX.dd-mm-yyyyhhmmss npanxx-npanxx.dd-mm-yyyyhhmmss |
Invalid NPAC region supplied |
Supply valid region name for command. |
| 2 |
LSMS_DIR environment variable is not set/defined. |
LSMS_DIR environment variable is not set |
Verify the environment variables or contact the My Oracle Support (MOS). |
| 9 |
/var/TKLC/lsms/free/data/npacftp/ <region> does not contain any download files. |
NPAC directory for <region> does not contain any download files |
No action necessary. |
| 3 |
/var/TKLC/lsms/free/data/npacftp/ <region> NPAC directory does not exist. |
NPAC FTP directory for <region> cannot be located |
| 5 |
The npacagent process is currently running for the <region> region. It must be stopped prior to importing by executing the following command: $LSMS_DIR/lsms stop <region> |
The npacagent process is running for specified region |
Stop the npacagent process for this region and try the command again. |
