Allows user to display the High Availability status of the server on which the command is run.
hastatus
The user can be logged in as any user.
/usr/TKLC/plat/bin/hastatus
None.
ACTIVE
None.
None.
| Exit Code |
Error Message |
Cause |
Suggested Recovery |
| 0 |
Success |
n/a |
n/a |
| 1 |
Failure |
Varies |
Contact the My Oracle Support (MOS) |
| 2 |
Query No Match |
Querying the status of a component, based on a condition, did not result in a match. Following are the most common causes, which are dependent upon the particular query. |
| 6 |
UnknownError |
Not known |
