Check for Running Backups
Both database backups and query server snapshots use the same file space on the LSMS. Before creating a snapshot on the LSMS, perform the procedure described in “Checking for Running Backups” to ensure that no database backups are running.
CAUTION:
If you attempt to create a snapshot while a backup is running, the backup will be interrupted, and the next time a backup is performed, it will take much longer to complete.
The following tasks also use temporary file space (as does a snapshot), so you may run out of file space if you attempt to create a snapshot after you have started but not yet finished any of these tasks:
