Returning the Surveillance Feature to Last Valid State
Use the lsmssurv last command to return the Surveillance feature to its last valid state. If the Surveillance Monitor should be running but it is not for any reason, then lsmssurv last will start it.
Log in as root on either server.
Type the following command:
lsmssurv last
The following messages appears:
LSMS Surveillance feature started
Repeat this procedure for the other server, if desired.
