Refresh the Telephony Fraud Protection File - ACLI
You can refresh the telephony fraud protection file from the ACLI with the
notify fped refresh command. This command updates the runtime table by reloading the entries from the file specified in the fraud-protection configuration.
Before You Begin
- SFTP the updated file to the E-SBC.
- Confirm that the name of the updated file matches the name of the configured file.
Procedure
Use the following procedure apply updates to the fraud protection file.
