Mapping SSL3 to TLSv1 Ciphers
The following table shows the mapping of SSL3 ciphers to TLSv1 ciphers:
| SSL3 | TLSv1 |
| SSL_RSA_WITH_NULL_MD5 | TLS_RSA_WITH_NULL_MD5 |
| SSL_RSA_WITH_NULL_SHA | TLS_RSA_WITH_NULL_SHA |
| SSL_RSA_WITH_RC4_128_MD5 | TLS_RSA_WITH_RC4_128_MD5 |
| SSL_RSA_WITH_RC4_128_SHA | TLS_RSA_WITH_RC4_128_SHA |
| SSL_RSA_WITH_DES_CBC_SHA | TLS_RSA_WITH_DES_CBC_SHA |
| SSL_RSA_WITH_3DES_EDE_CBC_SHA | TLS_RSA_WITH_3DES_EDE_CBC_SHA |
| SSL_DHE_RSA_WITH_DES_CBC_SHA | TLS_DHE_RSA_WITH_DES_CBC_SHA |
| SSL_DHE_RSA_WITH_3DES_EDE_CBC_SHA | TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA |
The Oracle® Enterprise Session Border Controller supports TLS_RSA_WITH_NULL_MD5 and TLS_RSA_WITH_NULL_SHA although neither does any encryption. These ciphers might be used for debugging purposes, and should not be deployed.
