Run Setup
Use the following procedure to run the Installation Wizard to configure the Web Server and setup the Web GUI.
To run the Installation Wizard:
In Superuser mode, type
run setup, and press Enter.
ORACLE# run setup
The Installation Wizard can also be invoked by the run setup quiet command that enables a less verbose presentation.The following displays.
========================================================= ----------------------------------------------------------- Thank you for purchasing the Oracle SBC. The following short wizard will guide you through the initial set-up. ----------------------------------------------------------- '?' = Help; '.' = Clear; 'q' = Exit CONFIGURATION WARNING: Proceeding with wizard will result in existing configuration being erased. Erase config and proceed (yes/no) [no] : =========================================================You can use:
- ‘?’ key to obtain query-specific help
- ‘.’ key to clear the field of the current setting.
- ‘q’ key to exit the wizard at any location in the setup process. Initiating the
q displays the following prompt:
Discarding changes and quitting wizard. Are you sure? [y/n]?:
Enter y to discard any changes and quit the installation wizard. The root prompt displays.
A “Warning” displays stating that using the wizard can overwrite (erase) the existing running configuration. If you want to back out of the setup process and not overwrite the current running configuration, you can enter q or enter No at the Erase config and proceed prompt. The root prompt displays.
Enter
yes at the prompt to continue the setup process, and press Enter.
Erase config and proceed (yes/no) [no] :yesThe following displays.
========================================================= Configuration will be backed up as bkup_setup_wizard_<MMM>_<DD>_<YY>_<HH>_<MM>_<SSS>.gz '-' = Previous; '?' = Help; '.' = Clear; 'q' = Exit GUI ACCESS If you want to allow GUI to access this SBC, enable this setting Enable Web GUI (yes/no) [yes] : =========================================================
You can use:
‘-’ key to navigate to the previous step in the setup process, if required, and change your response.
Enter
yes, and press Enter. Or enter
no to disable the Web GUI, and press Enter.
Enable Web GUI with HTTP connection. (yes/no) [yes] :yesThe following displays.
========================================================= WEB GUI MODE Choose which mode to enable for the web GUI Web GUI Mode 1 - basic 2 - expert Enter choice [1 - basic] : =========================================================
