ACLI Instructions and Examples
To configure RFC 2833 customization:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager and press Enter to begin configuring this feature.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
- rfc2833-timestamp—Set this parameter to enabled to use the estimated real departure timestamp on an injected RFC 2833 telephone-event packet.
- default-2833-duration—Set this parameter to the default value you wish to use when the Oracle® Enterprise Session Border Controller, creates or generates DTMF-indication messages.
- rfc2833-end-pkts-only-for-non-sig—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller, to only send the three RFC 2833 telephone-event end-packets to indicate a total event duration, rather than the running total from time=0.
- options—Set the options parameter by typing options, a Space, the option name min-signal-duration=x (where x is the value in milliseconds you want to use for the threshold) with a plus sign in front of it. Then press Enter.
- Save and activate your configuration.
