Time Zones
You must set the time zone on the Oracle® Enterprise Session Border Controller (E-SBC) manually by way of the ACLI. Oracle recommends that you set the time zone after first boot of the system.
Use the timezone-set command at the root prompt to launch the time zone wizard, where you specify your time zone settings. Note that the wizard automatically sets the daylight savings time for the geographic location you select.
