Configuring Advanced Logging
From Configure mode, define
sip-advanced-logging and
advanced-log-condition. The criteria that you configure remaps the message logging and modifies the system configuration. You must save and activate the changes to the configuration.
When configuring multiple
sip-advanced-logging configurations, note the following:
- The system evaluates each configuration individually in an OR relationship.
- The system evaluates all conditions and they must all match in an AND relationship.
