Enabling SNMPv3
The table below gives a brief overview of the SNMPv3 configuration on the Oracle® Enterprise Session Border Controller (E-SBC). The Caveats column describes the SNMPv1v2 configuration attributes that are ignored if SECURE-TRAP mode is enabled.
| Configuration | Description | Caveat |
| snmp-agent-mode | Set this attribute to SECURE-TRAP to enable SNMPv3. | Once SNMPv3 is enabled, the snmp-community and community-name attributes are ignored. |
| snmp-engine-id-suffix | Set this attribute as a string to customize and uniquely identify the SNMP Engine. | The show snmp-info command has been expanded to include the SNMP Engine Base, the SNMP Engine Suffix, and the SNMP Engine ID. |
| snmp-user-entry | Enter the user name, authorization password and privacy password. | The user, as defined in this object, must be added to the attribute user-list under trap-receiver in order to receive secured traps. |
| trap-receiver | Configure a trap-receiver with the IP address of the NMS that receives secured traps. | |
| user-list | Add users who are authorized to receive secured traps. | If instances of snmp-user-entry are configured, but no users are listed under user-list, a warning message is sent during a verify-config execution. |
