Configure the SNMP Community
Access the
snmp-community configuration element.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# snmp-community ORACLE(snmp-community)#
Type
community-name to
specify the SNMP community name of an active community where this
Oracle® Enterprise Session Border Controller can send or receive SNMP information.
access-mode—Set the
access level for all network management servers (NMSs) defined within this SNMP
community. The access level determines the permissions that other NMS hosts can
wield over this
Oracle® Enterprise Session Border Controller. The default is
read-only. The valid
values are:
read-only—allows GET requests.
read-write—unsupported.
ip-addresses—Specify
a valid IPv4 or IPv6 address within this SNMP community that corresponds to one
or more NMS that monitors or configures this
E-SBC. If you are
specifying more than one IP address, separate each IP address with a space and
enclose with parenthesis.
ORACLE#(snmp-community)ip-addresses (10.1.1.1 10.2.2.2) - Type done to save your configuration.
