SNMP Trap for Survivability
An Oracle® Enterprise Session Border Controller (E-SBC) MIB contains objects of management data, and also information about Simple Network Management Protocol (SNMP) traps, which enable an agent to notify the management station of significant events by way of an unsolicited SNMP message. When an element sends a TRAP packet, it can include an Object Identifier (OID) and value information (bindings) to clarify the event. For more information about SNMP on the E-SBC, see the MIB Reference Guide.
The E-SBC triggers an Enterprise SNMP trap when a SIP interface goes in or out of Survivability mode. This trap is called:
- snmp_survivability_mode_trap_send
This trap has been added to the SIP application MIB called ap-sip.mib. The trap information is as follows in this MIB:
apSipSurvivabilityNotif OBJECT IDENTIFIER ::= { apSipNotificationObjects 2 }
apSipSurvivabilityNotifObjects OBJECT IDENTIFIER ::= { apSipSurvivabilityNotif 1 }
apSipSurvivabilityNotifPrefix OBJECT IDENTIFIER ::= { apSipSurvivabilityNotif 2 }
apSipSurvivabilityNotifications OBJECT IDENTIFIER ::= { apSipSurvivabilityNotifPrefix 0 }
apSipSurvivabilityModeEnter NOTIFICATION-TYPE
OBJECTS { apSysMgmtSipInterfaceRealmName, apSysMgmtSipInterfaceIP }
STATUS current
DESCRIPTION
" The trap will be generated when SIP interface enters Survivability Mode."
::= { apSipSurvivabilityNotifications 1 }
apSipSurvivabilityModeExit NOTIFICATION-TYPE
STATUS current
DESCRIPTION
" The trap will be generated when SIP interface exits Survivability Mode and resumes normal operation."
::= { apSipSurvivabilityNotifications 2 }
apSipSurvivabilityNotificationsGroup NOTIFICATION-GROUP
NOTIFICATIONS {apSipSurvivabilityModeEnter,
apSipSurvivabilityModeExit }
STATUS current
DESCRIPTION
"Traps to monitor SIP interface Survivability feature."
::= { apSipNotificationGroups 2 }
The apSysMgmtSipInterfaceRealmName and apSysMgmtSipInterfaceIP objects are imported strings defined in ap-smgmt.mib.When this trap is generated, it contains the following information:
| realmname | Realm name of the SIP interface |
| ipaddr | IP address of the SIP interface |
| mode | Specifies whether or not the SIP interface is in survivability mode. Values included with the trap are:
0 - SIP interface is OK. It is not in Survivability mode. 1 - SIP interface is in Survivability mode. |
The following table identifies the Survivability OBJECT IDENTIFIERS in the Oracle MIB that the E-SBC supports.
| Trap Name: OID Number | Description |
| apSipSurvivabilityNotificationsGroupCap:
1.3.6.1.4.1.9148.2.1.21.3 |
Specifies the capability of the E-SBC to notify the Agent regarding Survivability on the SIP interface. |
1.3.6.1.4.1.9148.3.15.2.2 |
N/A |
1.3.6.1.4.1.9148.3.15.2.2.1 |
N/A |
1.3.6.1.4.1.9148.3.15.2.2.2 |
N/A |
1.3.6.1.4.1.9148.3.15.2.2.2.0 |
N/A |
1.3.6.1.4.1.9148.3.15.2.2.2.0.1 |
Specifies that the SIP interface has entered Survivability mode. |
1.3.6.1.4.1.9148.3.15.2.2.2.0.2 |
Specifies that the SIP interface has exited Survivability mode and resumed normal operation. |
1.3.6.1.4.1.9148.3.15.3.2.2 |
Specifies the notification from the E-SBC to the Agent regarding Survivability on the SIP interface. |
