PreviousNextJavaScript must be enabled to correctly display this content
Enabling or Disabling SNMP
SNMP is enabled by default when you selected
v1v2,
secure trap, and
v3 values for the
snmp-agent-mode element. Use this task to enable or disable SNMP on the
Oracle® Enterprise Session Border Controller
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system
Type
system-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
