Configuring The Oracle® Enterprise Session Border Controller as a Virtual Machine (VM)
Operating the Oracle® Enterprise Session Border Controller as a VM introduces configuration requirements that define resource utilization by the virtual machine. The applicable configuration elements allow the user to optimize resource utilization based on the application's needs and VM resource sharing.
Oracle® Enterprise Session Border Controller configuration for VM includes settings to address:
media-manager — Set media manager configuration elements to constrain bandwidth utilization, based on traffic type. See Media Manager Configuration for Virtual Machines in the Realms and Nested Realms Chapter.
system-config, [core configuration parameters] — Set these parameters to specify CPU resources available to DoS, forwarding and transcoding processes. This configuration applies to initial deployment and tuning tasks. You may need to change the default core configuration for functionality purposes during deployment; you may decide to change core configuration for performance purposes after deployment.
Early versions of this software used the bootparameter named other, set to isolcpus=[value]. Remove this setting for this and all ensuing versions of Oracle® Enterprise Session Border Controller software.
