Persistent ACLI more Parameter Configuration
To set the persistent behavior of the ACLI more feature across sessions:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
system
and press Enter.
ORACLE(configure)# system ORACLE(system)#
Type
system-config
and press Enter.
ORACLE(system)# system-config ORACLE(system-config)#
If you are adding this feature to an existing configuration, you need to select the configuration (using the ACLI select command) before making your changes.
- cli-more—Set this parameter to enabled if you want the ACLI more paging feature to work persistently across console or SSH sessions with the Oracle® Enterprise Session Border Controller. If you want to continue to set this feature on a per session basis, leave this parameter set to disabled (default).
- Save and activate your configuration.
