apUsbcSysDPDKObjects
This group of objects, found in the
ap-usbcsys.mib, provide a listing of DPDK statistics.
| MIB Object | Object ID: 1.3.6.1.4.1.9148.3.17.1.1.13 + | Description |
| apUsbcSysDPDKFwdPurpose | .1 | A bitset representing Forwarding cores. 1s represent forwarding cores, while 0s represent non-forwarding cores. |
| apUsbcSysDPDKDOSPurpose | .2 | A bitset representing DoS cores. Bits set to 1 represent DoS cores, while 0s represent non-DoS cores. |
| apUsbcSysDPDKSigPurpose | .3 | A bitset representing signaling cores. Bits set to 1 represent signaling cores, while 0s represent non-signaling cores. |
| apUsbcSysDPDKTransPurpose | .4 | A bitset representing transcoding Cores. Bits set to 1 represent transcoding cores, while 0s represent non-transcoding cores. |
| apUsbcSysDPDKCmdLine | .5 | System CmdLine string - as defined in /proc/cmdline. (including relevant bootparams.) |
| apUsbcSysDPDKFileMem | .6 | Total DPDK File Memory. |
| apUsbcSysDPDKSysMem | .7 | Total DPDK System Memory |
| apUsbcSysDPDKNum1G | .8 | Number of 1GB Hugepages allocated. |
| apUsbcSysDPDKNum2MB | .9 | Number of 2MB hugepages allocated. |
| apUsbcSysDPDKHypervisorType | .10 | The description regarding the system type and what hypervisor the system is running on (OVM, KVM, VMWare,...). |
| apUsbcSysDPDKAddFwdCores | .11 | Number of additional cores that may be used for forwarding. |
| apUsbcSysDPDKAddSigCores | .12 | Number of additional cores that may be used for signaling. |
| apUsbcSysDPDKAddTransCores | .13 | Number of additional cores that may be used for transcoding. |
