SIP INFO to DTMF Audio
SIP INFO will only be converted to DTMF audio tones only if RFC 2833 is not supported, dtmf-in-audio is enabled, the answer side supports a G711 codec, and transcoding resources are available.
Transcoding resources are always required in this scenario.
