Enabling Media Supervision Traps
The Oracle® Enterprise Session Border Controller (E-SBC) sends the following media supervision trap when functioning as a border gateway and the media supervision timer expires:
apSysMgmtMediaSupervisionTimerExpTrap NOTIFICATION-TYPE
OBJECTS { apSysMgmtCallId }
STATUS current
DESCRIPTION
" The trap will be generated when a media supervision timer
has expired. This behavior is disabled by default but may
be enabled by changing the 'media-supervision-traps'
parameter of the 'media-manager' configuration element. The
included object is the call identifer for the call which had
the timer expire."
::= { apSystemManagementMonitors 34 }
The system does not send this trap when functioning as an integrated E-SBC.The media supervision trap is disabled by default. You can enable the trap by changing the media-supervision-traps parameter to enabled in the media-manager configuration element.
