SIP Interface
To configure the RFC 2833 mode on a SIP interface:
In Superuser mode, type
configure terminal
and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter.
ORACLE(configure)# session-router
Type
sip-interface and press Enter.
ORACLE(session-router)# sip-interface
- If you are adding support for this feature to a pre-existing SIP interface, then you must select the specific configuration instance, using the ACLI select command.
rfc2833-mode—Set this parameter to either
transparent,
preferred, or
dual based upon the behavior your want for this SIP interface.
transparent—does not add RFC 2833 telephone-event into SDP if not present, and does not prefer.
preferred—adds RFC 2833 telephone-event media type into SDP and prefers to use this method for DTMF indication.
dual—adds RFC 2833 telephone-event media type into SDP and sends both SDP and signaling-based DTMF indications if possible.
- rfc2833-payload—Set this parameter to the media-type value you wish to use when inserting RFC 2833 telephone-events into an SDP offer. 101 is the generally accepted media type for RFC 2833 telephone-events.
- Save and activate your configuration.
