Import a Certificate Using SFTP
You can put the certificate file in the directory /ramdrv and execute the import-certificate command, or you can paste the certificate in PEM/Base64 format into the ACLI. If you paste the certificate, you may have to copy and paste it a portion at a time, rather than pasting the whole certificate at once.
