Enable SNMPv3
This procedure shows you how to enable SNMPv3 on your system, how to add users, and how to add users to authorized trap receivers.
To enable SNMPv3 by adding a user and passwords:
In Superuser mode, type
configure terminal and press Enter.
ACMEPACKET# configure terminal -
Type
system and press Enter to access the system-level configuration elements.
ACMEPACKET(configure)# system -
Type
snmp-user-entry
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ACMEPACKET(system)# snmp-user-entry ACMEPACKET(snmp-user-entry)#From this point, you can configure the SNMP user entry parameters. To view all SNMP user entry parameters, enter a ? at the system prompt.
- user-name—Enter the user name of a person who is authorized to receive secure traps. Valid values are alpha-numeric characters. Default is blank.
- auth-password—Enter the authentication password associated with the user-name value. The Oracle® Enterprise Session Border Controller (E-SBC) uses this password to authenticate the user before receiving secure traps. Valid values are alpha-numeric characters. Default is blank.
priv-password—Enter the privacy password associated with the user-name value. The
E-SBC uses this password to keep the session private for the user that is receiving the secure traps. Valid values are alpha-numeric characters. Default is blank.
The following is an example of an SNMP user entry configuration. Parameters not described in this section are omitted below.
snmp-user-entry user-name jsmith auth-password ******** priv-password ********
