Configure sdes-profile
A Session Description Protocol Security Descriptions (SDES) profile specifies the parameter values offered or accepted during SDES negotiation.
In the following procedure, use the key and salt parameters to generate the synchronous key used to encrypt and decrypt SRTP/SRTCP traffic originated by theOracle® Enterprise Session Border Controller (E-SBC). The E-SBC passes these concatenated values to the remote SRTP peer. Upon reception, the remote peer inputs the key and salt values to the negotiated encryption algorithm (AES in the current implementation), and derives the key required to decrypt SRTP/SRTCP traffic received from the E-SBC. The key parameter provides the basic keying material, while the salt (a bit string) provides the randomsess/entropy required by the encryption algorithm.
- Repeat steps 1 through 8 to configure additional SDES profiles.
