Configuring Nested Realms
When you are configuring nested realms, you can separate signaling and media by setting realm parameters in the SIP interface configuration, the H.323 stack configuration, and the steering ports configuration.
- The realm identifier you set in the SIP interface configuration labels the associated realm for signaling.
- The realm identifier you set in the H.323 stack configuration labels the associated realm for signaling.
- The realm identifier you set in the steering ports configuration labels the associated realm for media.
Constructing a hierarchy of nested realms requires that you note which realms you want to handle signaling, and which you want to handle media.
In the SIP port configuration for the SIP interface and in the H.323 stack configuration, you will find an allow anonymous parameter that allows you to set certain access control measures. The table below outlines what each parameter means.
| Allow Anonymous Parameter | Description |
| all | All anonymous connections allowed. |
| agents-only | Connections only allowed from configured session agents. |
| realm-prefix | Connections only allowed from addresses with the realm’s address prefix and configured session agents. |
| registered | Connections allowed only from session agents and registered endpoints. (For SIP only, a REGISTER is allowed for any endpoint.) |
| register-prefix | Connections allowed only from session agent and registered endpoints. (For SIP only, a REGISTER is allowed for session agents and a matching realm prefix.) |
