Specifying the LRT Location
After moving the DID-range-based LRT to the /code/lrt directory on the ESD, use the following procedure to specify the file’s location, and the lookup method.
Move to local-routing-config mode.
ACMEPACKET# configure terminal ACMEPACKET(config)# session-router ACMEPACKET(session-router)# local-routing-config ACMEPACKET(local-routing-config)#
Provide an alias for the LRT file. Later, you will use this alias
to assign the LRT to the local policy attributes.
ACMEPACKET(local-routing-config)# name WestCampus ACMEPACKET(local-routing-config)# -
Provide the name of the file that contains the XML-formatted LTR.
This file must currently exist within the /code/lrt directory.
ACMEPACKET(local-routing-config)# file-name didLRT.xml.gz ACMEPACKET(local-routing-config)# -
Specify the look-up type. For DID-based LRTs, enable
string-lookup to ensure that all ranges,
including those with an alphabetic prefix (for example, test123), are properly
evaluated.
ACMEPACKET(local-routing-config)# string-lookup enabled ACMEPACKET(local-routing-config)# -
Because the prefix-length (if any) is specified within the XML
file, ensure that the
prefix-length attribute is set to its default
value, 0.
ACMEPACKET(local-routing-config)# prefix-length 0 ACMEPACKET(local-routing-config)# - Retain default values for other parameters.
- Use done, exit, and verify-config to complete this configuration.
