Obtaining System Information about RTCP Generation
The Oracle® Enterprise Session Border Controller provides information about RTCP report generation within log files.
The log.mbcd file, when configured to capture at the DEBUG level, includes system messages related to invoking and firing rtcp-policy rules.
An example of applicable log information is provided below.
[XC] NatFlow::check_transcoding() [XC] SessionSetRtcpPorts for A: src=10001 dest=20001 [XC] NatFlow::check_transcoding() SessionSetRtcpOptions(A): [XC] RtcpPolicy "my_rtcp_policy"; rtcp-generate set to: RTCP_GEN_MODE_ALL_CALLS [XC] Will generate RTCP with CNAME=192.160.1.100:10001 [XC] NatFlow::check_transcoding() [XC] SessionSetRtcpPorts for B: src=10001 dest=20001 [XC] NatFlow::check_transcoding() SessionSetRtcpOptions(B): [XC] RtcpPolicy "my_rtcp_policy"; rtcp-generate set to: RTCP_GEN_MODE_ALL_CALLS [XC] Will generate RTCP with CNAME=172.16.1.100:10101
Error and non-error system messages related to RTCP generation can be found in log.sipd, log.mbcd, and log.xserv.
