Network Interface Configuration
These ACLI command sequences configure two network-interfaces. The first sequence configures a network-interface named m10, thus associating the network-interface with the phy-interface of the same name. The ACLI ip-address command assigns the IPv4 address 172.16.10.76 to the network-interface. In a similar fashion, the second command sequence associates the m01 network and phy-interfaces, and assigns an IPv4 address of 182.16.10.76.
ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m10 ORACLE(network-interface)# ip-address 172.16.10.76 ... ... ... ORACLE(network-interface)# ORACLE# configure terminal ORACLE(configure)# system ORACLE(system)# network-interface ORACLE(network-interface)# name m01 ORACLE(network-interface)# ip-address 182.16.10.76 ... ... ... ORACLE(network-interface)#
