Configure the P-Certificate-Subject-Common-Name From the ACLI
Use the following procedure to configure the P-Certificate-Subject-Common-Name on the Oracle® Enterprise Session Border Controller (E-SBC).
To configure the P-Certificate-Subject-Common-Name:
  1. In Superuser mode, type configure terminal, and press Enter.
    ORACLE# configure terminal
    ORACLE(configure)#
  2. Type session-router , and press Enter.
    ORACLE(configure)# session-router
    ORACLE(session-router)#
  3. Type enforcement-profile, and press Enter.
    ORACLE(session-router)# enforcement-profile
    ORACLE(enforcement-profile)#
  4. add-certificate-info—Enter sub-common name for the certificate attribute names to enable TLS certificate information caching, and for the inserting of cached certificate information into customized SIP INVITEs. Default: blank. Valid values:
    • sub-common name
    • sub-alt-name-DNS
  5. certificate-ruri-check—Enable this parameter if you want the E-SBC to cache TLS certificate information and use it to validate Request-URIs. Enabling this parameter allows the E-SBC to cache the TLS certificate information in a customized SIP INVITE. Default: disabled. Valid values:
    • enabled
    • disabled
  6. verify-certificate-info-register —Select whether or not to allow the E-SBC to add certificate information to the header of a REGISTER message for verifying a ruri against certificate attributes. Default: disabled. Valid values:
    • enabled
    • disabled
  7. Type done, and press Enter.
    ORACLE(enforcement-profile)# done
  8. Type exit, and press Enter.
    ORACLE(enforcement-profile)# exit
  9. Save the configuration.
