RedHat, Inc., JBoss Community
validation-api Version 1.1.0 Final
SourceForge
cglib (Code Generation Library) Version 2.2.2
This product includes software developed by, The Apache Software Foundation
(http://www.apache.org/).
The following applies to all products licensed under the Apache 2.0 License:
  1. You may not use the identified files except in compliance with the Apache License, Version 2.0 (the "License.")
  2. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0. A copy of the license is also reproduced below.
  3. Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  4. See the License for the specific language governing permissions and limitations under the License.
SpringSource
Spring Framework Version 3.1
Spring Framework 3.1
Copyright (c) 2002-2011 SpringSource, a division of VMware, Inc.
This product is licensed to you under the Apache License, Version 2.0 (the "License").
You may not use this product except in compliance with the License.
This product may include a number of subcomponents with separate copyright notices and license terms. Your use of the source code for the these subcomponents is subject to the terms and conditions of the subcomponent's license, as noted in the LICENSE file.
