Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22406 - Routing attempt failed due to internal resource exhaustion
Event Type:
RBAR
Description:
A message could not be routed because the internal "Request Message Queue" to the DSR Relay Agent was full. This should not occur unless the MP is experiencing local congestion as indicated by Alarm-ID 22200 - MP CPU Congested.
Severity:
Info
Instance:
<MPName>
HA Score:
Normal
Throttle Seconds:
10
OID:
eagleXgDiameterRbarRoutingAttemptFailureInternalResExhNotify
Recovery:
  1. If this problem occurs, it is recommended to contact My Oracle Support.
