Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
10200 - Remote database reinitialization in progress
Alarm Group:
CFG
Description:
The remote database reinitialization is in progress. This alarm is raised on the active NOAM server for the server being added to the server group.
Severity:
Minor
Instance:
<hostname of remote server>
HA Score:
Normal
Auto Clear Seconds:
This alarm does not autoclear.
OID:
apwSgDbReinitNotify
Recovery:
  1. Check to see that the remote server is configured.
  2. Make sure the remote server is responding to network connections.
  3. If this does not clear the alarm, delete this server from the server group.
  4. If the problem persists, it is recommended to contact My Oracle Support.
