Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
10108 - Duplicate scheduled log export task
Alarm Group:
LOG
Description:
A duplicate scheduled log export task has been queued.
Severity:
Minor
Instance:
<Target ID>
<Target ID> refers to the scheduled task ID found by running a report from Status & Manage > Tasks > Scheduled Tasks.
HA Score:
Normal
Auto Clear Seconds:
This alarm does not autoclear.
OID:
tekelecLogExportDupSchedTaskNotify
Recovery:
  1. Check the duration and/or frequency of scheduled exports as they are not completing before the next scheduled export is requested.
  2. If the problem persists, it is recommended to contact My Oracle Support for assistance.
