Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
33304 - DCA Runtime Errors
Alarm Group
DCA
Description
The script generated runtime errors.
Severity
Critical
Instance
The DCA App short name (DcaDalId.shortName) prefixed with "DCA:" and thread pool (Request, Answer or SBR Event)
HA Score
Normal
Auto Clear Seconds
60
OID
dcaDSRAppRuntimeErrorNotify
Recovery
  1. The error message generated by the Perl interpreter is included in the alarm's additional info.
    Fix the error accordingly and recompile the Perl script, or replace the Trial/Production version (depending on whether the DA-MP is a Trial DA-MP or not) with another script version.
    Because the compilation occurs in parallel while the previously compiled script is still running (and hence keeps raising the alarm), a successful compilation will not immediately clear the alarm. There will be an auto clear latency of 20 seconds that will clear the alarm.
