Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
19266 - Unexpected event received from remote TCAP peer
Event Type:
SS7
Description:
Unexpected event received from remote TCAP peer.
Severity:
Info
Instance:
Application name
HA Score:
Normal
Throttle Seconds:
30
OID:
awpss7TcapUnexpectedMsgFromRemoteNotify
Recovery:
  1. Determine if this condition indicates a software problem or unexpected TC User behavior.
  2. The event additional information field includes:
    • a description of what event was received and why it was unexpected
    • what was done with the operation or dialogue as a result
    • the first 80 octets of the message starting with the MTP3 routing label
  3. The message data can be used to determine the source of the malformed message.
  4. It is recommended to contact My Oracle Support for assistance if needed.
