Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
31114 - DB replication over SOAP has failed
Alarm Group:
REPL
Description:
Database replication of configuration data via SOAP has failed.
Severity:
Minor
Instance:
May include AlarmLocation, AlarmId, AlarmState, AlarmSeverity, and bindVarNamesValueStr
HA Score:
Normal
Auto Clear Seconds:
3600
OID:
comcolDbReplicationSoapFaultNotify
Recovery:
  1. This alarm indicates a SOAP subsystem is unable to connect to a server, due to networking issues or because the server is not available. Investigate the status of the server and verify network connectivity.
  2. If no issues with network connectivity or the server are found and the problem persists, it is recommended to contact My Oracle Support.
