19251 - Ingress message rate
- Alarm Group:
- SS7
- Description:
- The ingress message rate (messages per second) for
the MP is approaching or exceeding its engineered traffic handling capacity.
- Severity:
- Minor, Major, Critical as shown in the GUI under
- Instance:
- N/A
- HA Score:
- Normal
- Auto Clear Seconds:
- This alarm does not autoclear.
- OID:
- awpss7IngressMsgRateNotify
Recovery:
If one or more MPs in a
server
site have failed, the traffic will be distributed among the remaining MPs in
the
server
site. You can monitor MP
server
status from
The misconfiguration of STP routing may result in
too much traffic being distributed to the MP. You can monitor the ingress
traffic rate of each MP from
. Each
MP in the
server
site should be receiving approximately the same ingress transaction per second.
There may be an insufficient number of MPs
configured to handle the network traffic load. You can monitor the ingress
. If
all MPs are in a congestion state, then the offered load to the
server
site is exceeding its capacity.
If the problem persists, it is recommended to
contact
My Oracle Support.
