Go to primary content
Oracle® Communications Alarms and KPIs
Release 8.3
E93200
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
22729 - PCRF Not Configured
Alarm Group:
PCA
Description:
PCRF Not Configured
Severity:
Major
Instance:
Policy Binding Region Place Association Name
HA Score:
Normal
Auto Clear Seconds:
0 (zero)
OID:
pdraPcrfNotConfiguredNotify
Cause:
This alarm raises when the P-DRA completes initialization and determines that the PCRF's are not configured.
Diagnostic Information:
  • Check the NOAM GUI at Main Menu > Policy and Charging > Configuration > Policy DRA for further PCRF configuration.
  • Check for any missing configuration or capture this screen for further analysis.
Recovery:
  1. Check the NOAM GUI at Policy and Charging > Configuration > Policy DRA for further PCRF configuration.
  2. Check the event history logs in Alarms & Events.
  3. If the problem persists, it is recommended to contact My Oracle Support.
