32305 - Server Platform process error
- Alarm Group:
- PLAT
- Description:
- This alarm indicates either the minimum number of
instances for a required process are not currently running or too many
instances of a required process are running.
- Severity:
- Major
- Instance:
- May include AlarmLocation, AlarmId, AlarmState,
AlarmSeverity, and bindVarNamesValueStr
- HA Score:
- Normal
- Auto Clear Seconds:
- 0 (zero)
- OID:
- eagleXgDsrTpdPlatProcessErrorNotify
- Alarm ID:
- TKSPLATMA6
Recovery:
Rerun syscheck in verbose mode.
If the alarm has been cleared then the problem is
solved..
If the alarm has not been cleared then determine the
run level of the system.
If system run level is not 4 then determine why the
system is operating at that run level.
If system run level is 4, determine why the required
number of instances process(es) are not running.
If the alarm persists, it is recommended to contact
My Oracle Support
and provide the system health check output.
