Go to primary content
Oracle® Communications Diameter Signaling Router Diameter User's Guide
Release 8.3
E93183
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Editing a Local Node
Use this task to edit a Local Node.
When the Diameter > Configuration > Local Nodes [Edit] page opens, the fields are initially populated with the current values for the selected Local Node.
Configuration considerations:
  • The Local Node Name cannot be changed.
  • The following fields cannot be edited if there is at least one associated Enabled connection:
    • Realm
    • FQDN
    • SCTP Listen Port (and the Transport Protocol is SCTP)
    • TCP Listen Port (and the Transport Protocol is TCP)
    • DTLS/SCTP Listen Port
    • TLS/TCP Listen Port
    • RADIUS UDP Server Ports
    • RADIUS UDP Client Ports
    • Enable RADIUS UDP Port Range Start
    • Enable RADIUS UDP Port Range End
    • Verification Mode
    • Certificate Type
    • Certificate Name
    • Connection Configuration Set
    • CEX Configuration Set
  • IP Address (cannot be removed if there is an Enabled connection, but a new IP Address can be added)
  1. Click Diameter > Configuration > Local Nodes.
  2. Select the Local Node you want to edit, then click Edit.
  3. Update the relevant fields.
    For more information about each field, see Diameter Local Node Configuration Elements.
    The value for an entry in a list can be removed by selecting --Select-- in the list, or selecting the X at the end of the list (if an X is available).
  4. Click OK, Apply, or Cancel.
