Go to primary content
Oracle® Communications Diameter Signaling Router Diameter User's Guide
Release 8.3
E93183
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Deleting a Vendor
Use the following procedure to delete a Vendor.
A Vendor cannot be deleted if the Vendor is used in any AVP definitions in the dictionary.
  1. Click Diameter > AVP Dictionary > Vendors.
  2. Select the row that contains the Vendor to be deleted.
  3. Click Delete.
    A popup window appears to confirm the delete.
  4. Click:
    • OK to delete the Vendor.
    • Cancel to cancel the delete function and return to the Diameter > AVP Dictionary > Vendors page.
    If the Vendor is used in any AVP definitions in the dictionary, then the Vendor is not deleted and an error message appears.
