Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.3
E93185
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Enable the PCA Application
Use this task to enable the PCA application. For each Active SOAM,
  1. Click Diameter > Maintenance > Applications.
    The Diameter > Maintenance > Applications page appears.
  2. Under DSR Application Name, select each PCA row.
    To select more than one row, press and hold Ctrl while you click each row.
  3. Click Enable.
  4. Verify the application status on the page.
    The Admin State, Operational Status, Operational Reason, and Congestion Level in each of the selected rows should change respectively to Enabled, Available, Normal, Normal.
