| Oracle® Communications Diameter Signaling Router Policy and Charging Application Release 8.3 E93185 |
![]() Previous |
![]() Next |
If Diameter messages need to be routed in between DSR sites (nodes), set up the routing as needed.
This is likely in 3-site redundancy deployments because many PCEFs likely only support primary and secondary connections. In such deployments routing can be set up between the three sites.
