Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.3
E93185
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Exporting a network element configuration file
The network element Export button generates an installation script file used for configuration purposes. Use this procedure to export the configuration parameters of a network element:
  1. Click Configuration > Networking > Networks.
  2. Select the target network element tab.
    Network elements are presented in tabular form. If the target network element is not visible in the available screen space use the scroll right/left buttons located below the tool bar area and to the right or left of the visible tabs.
  3. Click Export.
    A file dialogue box appears prompting you to open or save the configuration file. By default the name format of the output file is NE_<yyyymmdd>_<hhmmss>_<zone>.xml. You may change this as needed.
