Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.3
E93185
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Clear Field Control
The clear field control allows you to clear the value from a list. The clear field control is available only on some lists.
Click the X next to a list to clear the field.
Figure 2-9 Clear Field Control X
