Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.3
E93185
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Inserting CTFs
Use this task to insert(create new) CTFs.
The fields are described in CTFs elements.
  1. On the Active SOAM, click Policy and Charging > Configuration > Online Charging DRA > CTFs.
    The Policy and Charging > Configuration > Online Charging DRA > CTFs page appears.
  2. Click Insert.
    The Policy and Charging > Configuration > Online Charging DRA > CTFs [Insert] page opens.
  3. Enter a unique CTF Peer Node Name in the CTF Peer Node Name field.
    This name uniquely identifies the CTF Peer Node.
  4. Enter an optional comment in the Comments field.
  5. Click:
    • OK to save the new CTF and return to the Policy and Charging > Configuration > Online Charging DRA > CTFs page.
    • Apply to save the new CTF and remain on this page.
    • Cancel to return to the Policy and Charging > Configuration > Online Charging DRA > CTFs page without saving any changes.
    If OK or Apply is clicked and any of several conditions exist, an error message appears:
    • The entered CTF is not unique (already exists).
    • Any fields contain a value that contains invalid characters or is out of the allowed range.
    • Any required field is empty (not entered).
    • Adding the new CTF would cause the maximum number of CTFs (2500) to be exceeded.
