| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.3 E93199 |
![]() Previous |
![]() Next |
This table describes filter control elements of the user interface.
Table 2-6 Filter Control Elements
| Operator | Description |
| = | Displays an exact match. |
| != | Displays all records that do not match the specified filter parameter value. |
| > | Displays all records with a parameter value that is greater than the specified value. |
| >= | Displays all records with a parameter value that is greater than or equal to the specified value. |
| < | Displays all records with a parameter value that is less than the specified value. |
| <= | Displays all records with a parameter value that is less than or equal to the specified value. |
| Like | Enables you to use an asterisk (*) as a wildcard as part of the filter parameter value. |
| Is Null | Displays all records that have a value of Is Null in the specified field. |
Not all filterable fields support all operators. Only the supported operators are available for you to select.
