Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.3
E93199
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Configuring Config_Params Tables
Use this task to configure SoR Config_Params tables.
The available GUI choices differ between the SO and the NO.
The SoR Config_Params tables fields are described in Table 4-2.
  1. Navigate to DCA Framework > Steering of Roaming > Application Control.
  2. Select a Version Name.
  3. Click the appropriate action button. For example, Config Tables and Data on the NO or Config Data on the SO.
    The active buttons are related to your site configuration.
  4. Select Config_Params.
  5. Select an action that corresponds to the task you want to perform. For example, View on the SO.
  6. Fill out the fields to define or edit the selected table. Some fields are cannot be edited; this is related to their provisioned values and permissions.
  7. Click OK or Apply to complete the task.
