Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.3
E93199
Contents
Previous
Next
Disabling SoR
Use this task to disable SoR on the SO.
Navigate to
Diameter
Maintenance
Applications
Select
DCA_SOR
Click
Disable
The SoR instance is removed from the GUI menu.
