Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E3901 Cmd Rej: CGPA entry is referred by CDPA entries
All CdPA entries that are assigned to the CdPA entry must be deleted before the CgPA entry can be deleted.
Recovery
  1. Display the existing CdPA entries for the CGPA entry to be deleted. Enter the rtrv-gsmmap-scrn command.
  2. Delete the CdPA entries. Refer to the Database Administration - Features User's Guide for assistance.
  3. Re-enter the dlt-gsmmap-scrn command that generated this error message.
    Contact My Oracle Support if this error message appears again. See My Oracle Support (MOS).
