Go to primary content
Oracle® Communications EAGLE Commands Error Recovery Reference
Release 46.6
E93312 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
E4837 Cmd Rej: MAPSET and MRNSET cannot be specified together
The xlat=none parameter must be specified before the mapset and mrnset parameters can be specified together in the command.
Recovery
Re-enter the command that generated this error message, specifying a valid combination of parameters. Refer to the command description in Commands User's Guide and to the Database Administration - GTT User's Guide for assistance.
